Heat transfer parallel vs. series
In heat transfer, components in parallel allow heat to transfer simultaneously, resulting in the same temperature difference (ΔT) across each component. This concept parallels electrical circuits, where voltage remains constant across parallel components. The principles of Ohm's law can be applied to thermal circuits, indicating a similar relationship between heat transfer and electrical flow. Understanding these parallels enhances the analysis of thermal systems. This comparison underscores the importance of recognizing how heat transfer behaves in different configurations.
gfd43tg
Hello,
In heat transfer, for the components to be in parallel, does that simply mean that the heat is transferring through all of the components at the same time, such that ΔT is the same for both, similar to how the voltage is the same for two components in parallel of a circuit?
Yes. Ohm's law also applies to thermal circuits in the same way it does to electrical circuits.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
