Heisenberg Uncertainy Principle
The discussion focuses on the calculations related to the Heisenberg Uncertainty Principle and the de Broglie wavelength of electrons in a beam emitted by modern electron microscopes. The wavelength of the electrons is calculated to be approximately 4.8494 x 10^-12 m. A minimum uncertainty in electron position of 1 angstrom (10^-10 m) leads to a maximum acceptable uncertainty in momentum calculated as 5.27 x 10^-25 kg·m/s. Participants clarify that the wavelength calculation pertains to de Broglie rather than the uncertainty principle itself. The conversation emphasizes the importance of distinguishing between these two concepts in quantum mechanics.
Dars
Modern electron microscopes used in biological research emit a beam of electrons with a
velocity of 1.5x108 m/s
a. What is the wavelength of an electron in the beam?
b. The wavelength of the particle determines the resolution of the microscopy. Assume
that you desire a minimum uncertainty in electron position of 1A. Using the uncertainty
principle, what is the maximum acceptable uncertainty in the momentum of the
electrons?
lamda = h/mv
p_0 = h/(4pi*delta x)
a) lamda = h/mv = 4.8494*10^-12m
b) p_0 = h/(4pi*delta x) = 5.27*10^-25 kg*ms^-1? thanks
a) is not Heisenbergs uncertainty principle, this is de broglie wavelength
b) is "1A" one "angstrom" 10-10m?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
