HELP A problem on determine electric field in vector form
Kudo Shinichi
HELP!A problem on determine electric field in vector form
The electric potential due to a charge distribution is given by V(x,y)=((100x)/(x2+y2)3/2)*Volts
where the distances are in meters. What is the electric field (vector) at the position x=2m, y=0.2m?
V(x,y)=((100*2i)/(22i+0.22j)3/2)*volts
V(x,y)=(200i/(8i+0.008j))*volts
This is how I tried to solve the problem but I don't think that I did it correctly because I don't think that I can write a function with two directions together.
Can anyone help me with it? thank you very much
One thing is clear: You aren't reading your textbook.
First, they ask for the electric field, not the electric potential. So you are not supposed to evaluate V(x,y) at the given point. And even if you were supposed to do that, it makes no sense to insert the unit vectors \hat{i} and \hat{j} in there (where would those come from anyway??).
Please look in your book and find the definition of electric field in terms of electric potential. Then we can get started.
Sorry about that I didn't read the problem properly...
dV=-E*dl
E=-dV/dl
Then separate the x and y direction
Ex=-\deltaV/\deltax
Ex=-(100/(3/2(x2+y2)1/2*(2x+y2))
Ey=-\deltaV/\deltay
Ey=(100x/(3/2(x2+y2)1/2*(x2+2y))
then sub in x and y
is it right?
Your derivatives are wrong. If you post the steps you took to calculate them then I can show you where you made a mistake.
Ex=-\deltaV/\deltax
For this only we only have to derive x and let y be constant
the original equation is 100x/(x2+y2)3/2
since we only need to derive x
then the equation becomes
100x-->100
use chain rule to do the following=outside derivative times inside derivative
(x2+y2)3/2
3/2(x2+y2)1/2*(2x)
Ex=-(100/(3/2(x2+y2)1/2*(2x))
same for y but for this only derive y and let x be constant
Ey=-\deltaV/\deltay
Ey=(100x/(3/2(x2+y2)1/2*(2y))
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
