Who Hits the Ground First? - Gravity Explained
  • Thread starter Thread starter khizman
    Gravity
When two people of different weights jump from a building, they will hit the ground simultaneously due to gravity, assuming negligible air resistance. In a vacuum, like the moon, both would experience the same acceleration regardless of weight. On Earth, air resistance affects the fall, with a heavier body potentially facing greater resistance due to its larger profile. However, for short jumps where air resistance is minimal, both individuals will fall at the same rate due to gravity. The discussion highlights the importance of understanding the effects of air resistance and gravitational acceleration.
khizman
If two people - one weighing 10 stone and the other weighing 20 stone - both jump off a building who would hit the ground first?
I know they would land at the same time but why?:confused:
It all depends on the air resistence - if there is any.
If they jumped of a building on the moon, an airless environment, then they would both have the same acceleration and would hit the ground at the same time, regardless of their weights.
On the earth, where there is an atmosphere, then there would be air resistence, which would slow down the fall.
Air resistence would depend upon the profile, or outline shape of the falling bodies, as well as other factors. A grosser body would have a greater profile than a leaner body and so would have a greater amount of air resistence. The more resistence, the longer it would take to fall.
If air resistance is negligible (such as for a short jump) the acceleration due to gravity of all things is the same. This comes from comparing two formulas. One is the simple formula for calculating weight (force of gravity) near the Earth's surface. The other formula is Newton's second law. Rearrange this second law formula to solve for acceleration.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
