Melting Ice Cube: Time Needed for 3-Ton Ice Cube with Golden Bars
  • Thread starter Thread starter baky0905
    Cube Ice
To determine the time needed for a 3-ton ice cube measuring 1.5m on each side to melt at an average temperature of 6.2°C, one must consider the heat transfer involved in melting ice. The presence of two golden bars within the ice cube may affect the melting rate due to their thermal conductivity. Calculations should include the specific heat of ice, the latent heat of fusion, and the heat transfer from the surrounding environment. Participants in the discussion emphasize the importance of showing work to receive assistance. The user expresses urgency for help due to an upcoming exam.
baky0905
Help...melting ice cube.
How much time is needed for an ice cube ((1.5x1.5x1.5)m, 3tons of mass with two golden bars within an ice cube to melt. Average temerature of the month is 6.2 ˙C
Thank you very much!
Welcome to the forums. Please note that you must show some work before we can help you with homework problems. So, what have you done thus far?
I would gladly show some work in the near future, but I need some help fast, as soon as possible. Sorry if I trouble you.
Thanks for every help I receive!
I will return the help when my exam month passes.
