Help My Friend With His Final Year Design Project
A user seeks assistance for a friend's final year design project involving the conversion of a 7th order high pass Butterworth filter from lumped elements to microstrip format, specifically for a cutoff frequency of 3 GHz. The discussion highlights that while high pass filters typically consist of series capacitors and shunt inductors, these can be adapted using transmission lines. Suggestions include replacing shunt inductors with shorted transmission lines and series capacitors with opened transmission lines. Additionally, the Kuroda transformation and Richards transformation are recommended as methods to facilitate this conversion. The conversation emphasizes the challenges of implementing high pass filters with distributed elements but notes that band pass filters with high frequencies are feasible.
Zanjabeel0
My friend is doing this for his final year design project and has hit a brickwall in terms of understand the actual process. Any help would be appreciated!
Welcome to the PF.
Could you provide some context, examples, and a lot more detail for this question please? What do you mean by the term "conversion" in the context of electronic filters?
Likes Zanjabeel0
He designed a 7th order high pass Butterworth filter with lumped elements. He wants to impliment the filter as a microstrip.
He's stuck at the conversion from lumped elements to microstrip. The cut off frequency is 3 Ghz.
It is not possible to build a high pass filter with distributed elements.
However, band pass filters with very high top ends are possible and work for most applications.
Likes Zanjabeel0
Hi,
Well, Highpass filters contain series caps and shunt inductors.
shunt inductors can be replaced by shorted transmission lines.
series capacitors can be replaced by opened transmission lines. (but you can't realize this)
replace all lumped with distributed then use kuroda transformation to convert to a microstrip filter with only shunt and series t-line components.
look up RICHARDS TRANSFORMATION and KURODA IDENTITY (MAYBE YOU CAN FIND AN ONLINE PROGRAM)
(Sorry I don't want to spend more time on this but I'll check again later)
Likes Zanjabeel0
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
