Help on Thesis Topic: Applied Physics, Programming & Experiments
  • Thread starter Thread starter boracay
    Thesis Topic
The discussion centers on seeking guidance for a thesis topic in applied physics, programming, or experimental setups. Participants emphasize the importance of consulting with academic advisors and professors for topic selection and approval. Suggestions include exploring thin film magnetics as a potential area of focus. Engaging with faculty is crucial since access to labs and equipment will depend on their approval. Overall, collaboration with professors is essential for successfully navigating the thesis process.
boracay
help on thesis topic!
please, please.. help me find a topic for my thesis..
particularly, I'm interested in applied physics topics, programming or experimental set-up will do.. any suggestions?..
What thesis are you seeking advice on? Surely you have an advisor that you can talk to, and who should help you select such a topic.
Undergrad or graduate? What background do you have? You could do some thin film magnetics stuff.
I would definitely talk to professors at your school. Whatever you end up doing, it is likely that you would be using their labs and equipment to do the necessary experiments. That pretty much means you'll be needing the approval of the professor who runs the particular lab where you end up doing the work.
