Help Solve Physics Homework: Computer Base Unit of Mass
The discussion revolves around solving a physics homework problem involving a 7.5 kg mass being dragged on a smooth desk with a normal contact force of 23 N and a tension angle of 23° to the horizontal. Participants clarify that the coefficient of kinetic friction is not provided, and while a smooth surface suggests low friction, it does not imply zero friction. The normal force of 23 N is significant in determining the forces acting on the mass. One participant proposes a solution involving the sum of forces in the vertical direction to find the total tension in the person's arm. The conversation emphasizes the importance of understanding the relationship between normal force, gravity, and tension in solving the problem.
SherlockIsReal
Hi! Another Physics homework question that needs solving immediately! Thank you in advance.
A computer base unit of mass 7.5 kg is dragged along a smooth desk. If the normal contact force is 23 N and the tension in the arm of the person dragging it acts at 23° to the horizontal, then what is the total tension in the persons arm?
It seems to me that you have left out a material fact. You will need to tell us what the co-efficient of kinetic friction is.
AM
AM
There can't be a coefficient of kinetic friction if there is no friction right, and there is no friction because it is smooth desk, right?
Being smooth does not necessarily imply a 0 coefficient of friction. Roads can be smooth too, but they have friction. But in looking at it again, it appears here that the question expects you to assume that it is negligible.
What does the fact that the normal force is 23N tell you?
AM
Andrew Mason said:
Being smooth does not necessarily imply a 0 coefficient of friction. Roads can be smooth too, but they have friction. But it appears here that the question expects you to assume that it is negligible.
AM
I think I got it. Would it make sense to solve it this way?
∑ Forces in y direction = Force Normal - Force gravity + Force tension in y direction
Yes. That would be right.
AM
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
