Engineering Help Solving Circuit Variables Problem
To solve the circuit variables problem, start by expressing power as the product of current and voltage, P = I * V, using the given functions for v(t) and i(t). Take the derivative of power with respect to time and set it to zero to find critical points, which indicate maximum power. Remember to consider initial conditions, particularly that power is zero for t < 0 due to no current. After finding the time that maximizes power, substitute it back into the power equation to determine the maximum power. The discussion also hints at using the provided information to calculate total power delivered to circuit elements.
Locha
Hey
Can Anyone Help Me to solve in this problem the a question
the one of the time
thank you,
Best Regards
This is not the proper place for homework help.
To solve: how does one go about getting an extrema? What does this mean?
Quick answer: since we know that power may be written as the product of the current and the voltage, you are given the two equations for v(t) and i(t). Write this out and to find the maximum power take the derivative of each side
\frac{d}{dt} P= \frac{d}{dt} \left( i(t) \cdot v(t) \right) [\tex]<br /> set this equal to zero and find the time. Note the initial conditions given in the problem statement. Take this solution for t back into the power equation to find the maximum power. This should get you started.
sorry for putting it in the wrong section, am new here but can anyone try to make it more clear for me about this problem , a question?
thanks
you're given the voltage and the current as functions of time, the product of these two gives an expression for the power.
P = I V
Now take the derivative with respect to time, and solve for time, remember from calc, that the critical points are those for which the slope of the tangent line is zero. Once you found a time, remember that for t<0, there's no current -> no power. So this time will answer (a), now take your result for (a) and substitute it into your equation for P, to get the maximum power. For (c) then how do you find the total power delivered to any circuit element. Hint: you have enough information to find this one too. hope this helps, sincerely, x
