Help to Understand Torque Equation for Ladder
  • Thread starter Thread starter brad sue
The discussion focuses on understanding the torque equation for a ladder resting against a wall. The key points include calculating the torque by considering the perpendicular distances from the point of rotation to the line of action of the forces. The torque due to the wall's reaction force (Nwall) is determined by its distance from the ground, while the torques from the ladder's weight and the man's weight are calculated using their respective perpendicular distances. It is emphasized that the distances should be measured perpendicularly to the direction of the forces involved. Understanding these principles is crucial for accurately setting up the torque equation.
brad sue
Hi , please help me to understand how to set up the equation for the torques.
This is the context:
A ladder of length l=5m and weigth wladder=160N rest against a wall. its lower end is at 3m from the wall.
A man weigthing 740N climbs 1 m along the ladder.
Nwall is the reaction ladder-wall.
(counterclock wise direction is considered positive)
The equation of the torque (equilibrium) about the bottom of the ladder is:
Nwall*4 -160* 1.5-740*1*(3/5).
=0.
I don't know how they get the equation especially the underlined coefficients.
My problem is that I don't know which distance to consider when computing for the torque in this case: the distance in respect to x axis, y-axis or along the ladder.
I hope I was clear enough
Thank you
B
Let A be the point where the ladder rests against the wall.
Let B be the point where the ladder rests against the ground.
Let C be the corner of the wall and the ground.
I assume that the wall is frictionless and that there is friction between the ladder and the ground. You probably have a coefficient of static friction, yes ?
The ladder and the wall and the ground form a triangle. This triangle is a 3-4-5 triangle. This simplifies some of the trig with cos@ = 3/5 and sin@ = 4/5, where @ is the angle between the ladder and the ground.
About your torque equation
Nwall is at A and is normal to the wall. Hence the perpindicular distance of Nwall from the ground, and hence also from the point B, is 4m, giving T1 = Nwall*4.
The torque of wladder about B is the force wladder times the perpindicular distance from B to the line of action of wladder, which is 2.5m*cos@, giving T2 = wladder*2.5*(3/5) = wladder*1.5.
The torque of the man about B is similarly given by T3 = 740*1*cos@ = 740*1*(3/5).
Since T2 and T3 are clockwise torques, then they are negative.
So,
Ttotal = T1 - T2 - T3 = Nwall*4 - wladder*1.5 - 740*1*(3/5).
When computing the torques, use either the x-axis or y-axis depending upon the direction of the forces.
If the force(s) is parallel to the x-axis, take the distance along the y-axis, and vice versa.
The distance should always be perpindicular to the line of action of the force.
So,
Thank you very much Fermat. so the key is to take perpendicular distance when calculating for the torque.
That's right. There should always be a right angle between the force and the distance measured.
