Help Understanding 74LS169 Binary Counter
  • Thread starter Thread starter JerryG
    Binary Counter
The 74LS169 is a 4-bit up/down binary counter that requires understanding its various inputs for proper usage. Key inputs include the count enable, up/down control, and reset functions, which dictate its counting behavior. Users are encouraged to consult the datasheet for detailed information on each input and operational characteristics. A link to the datasheet is often shared in discussions for quick reference. Understanding these components is essential for effectively implementing the 74LS169 in projects.
JerryG
Can someone explain to me or refer me to a site that explains how to use a binary counter such as the 74LS169 4 bit up/down binary counter? I'm not sure what all of the inputs do.
The datasheet should answer those questions. Can you post a link to the datasheet?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
