Finding the Value of C and Solving for Roots in a Quadratic Equation
  • Thread starter Thread starter discombobulated
To find the value of C in the quadratic equation f(x) = 6x² + 12x + c, the discriminant must equal zero for equal roots, leading to the equation 144 - 24c = 0, which simplifies to c = 6. For part b, solving the equation f(x) = 0 with c = 6 results in 6x² + 12x + 6 = 0, which factors to (x + 1)(6x + 6) = 0, yielding the root x = -1. The quadratic formula could also be applied for verification, confirming the solution is correct. The calculations were validated by other participants in the discussion.
discombobulated
ok this is the question:
f(x) = 6x2 + 12x + c where C is a constant.
a) Given f(x) =0 has equal roots, find the value of C.
so this what i did for this part:
b2- 4ac = 0 (formula for discriminant)
122-4(6xC) =0
144-24c=0
6-C=0
c=6 (is that right?)
Now for the next part:
b) Hence, solve f(x) = 0
6x2+12x+6=0
(x=1)(6x+6)=0
x=-1 x= -6/6 = -1
I wasn't really sure what i was doing but i tried to work it out and this is what i did but I'm not sure if it's right. (i don't think it is!) Can somebody help please!
a) Correct.
b) I would've used the quadratic formula. It's correct, though.
really? wow i was convinced it was wrong, thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
