Verifying the Conservativity of F and Finding Scalar Potential for F=-gradV"
  • Thread starter jlmac2001
In summary, the conversation discusses ways to determine if a force is conservative and how to find the scalar potential function for a given force. One method is to find the potential function directly, while another is to evaluate the curl of the force and check if it is zero. The conversation also provides an example of finding the potential function for the given force F= i - zj - jk.
jlmac2001
75
Problem: Verify that F= i - zj - jk is conservative, and find the scalar potential V(x,y,z) such that F=-gradV.
How do you tell if this is conservative?
will the scalar potential be: F=-gradV=-(-k-j)= (k+j)
Uh- did you notice that (k+ j) is not even a scalar? Or that "grad" is only defined for scalar functions so that "-grad V" is not defined?
You are going the wrong way: you need to find a function V(x,y,z) such that -gradF= V. That is, we seek a function V(x,y,z) such that FVx= -1, Vy= -z and Vz= OOPs, I have absolutely no idea what you mean by "-jk". I am going to assume that you meant "-yk" and mistyped: Fz= -y.
Okay, if there exist such a function then Vxy=
(-1)y= 0 and Vyx= (-z)x= 0. Okay that's possible: Vxy= Vyx as expected. Vyz= (-z)z= -1 and Vzy= -yy= -1. Yes! We have Vyz= Vzy.
Finally, Vxz= (-1)z= 0 and Vzx= (-y)x= 0.
Yes, is conservative.
We must have Vx= 1 so V(x,y,z)=x+ g(y,z) (If g depends only on y and z, then it dervative with respect to x is 0).
The Vy= gy(y,z)= -z so g(y,z)= -yz+ f(z) and V(x,y,a)= x- yz+ f(z). Then Vz= -y+ f'(z)= -y (assuming thatit was supposed to by -yk rather than -ik) so f'(z)= 0 and f is a constant, C. V(x,y,z)= x- yz+ C.
One way is just find the potential function, like Halls did.
Another way is to evalute the curl of the force; if it's zero, the force is conservative and there exists a potential function.
What is the purpose of verifying the conservativity of F?
The purpose of verifying the conservativity of F is to ensure that the vector field F is a conservative field. A conservative field is one in which the line integral of the vector field along any closed path is equal to zero. This property is important in various fields of physics, such as electromagnetism and fluid dynamics.
How do you verify the conservativity of F?
To verify the conservativity of F, one can use the curl operator. If the curl of F is equal to zero, then F is a conservative field. This means that the vector field can be described as the gradient of a scalar potential, which is useful for further analysis and calculations.
What is the significance of finding the scalar potential for F=-gradV?
Finding the scalar potential for F=-gradV is significant because it allows us to express a vector field as the gradient of a scalar function. This simplifies calculations and analysis of the field, making it easier to understand and work with.
What are the steps involved in finding the scalar potential for F=-gradV?
The steps involved in finding the scalar potential for F=-gradV are as follows:
  • Calculate the curl of F and verify that it is equal to zero.
  • Write the vector field F in terms of its component functions.
  • Set up a system of partial differential equations by equating the components of F to the corresponding partial derivatives of the scalar potential V.
  • Solve the system of equations to find the scalar potential V.
What are the applications of verifying the conservativity of F and finding the scalar potential for F=-gradV?
The applications of verifying the conservativity of F and finding the scalar potential for F=-gradV are numerous. In physics, it can be used to analyze and understand conservative forces, such as gravitational and electric forces. In engineering, it is useful for calculating work done by conservative forces and for designing efficient systems. It also has applications in fluid dynamics, where conservative vector fields can represent the velocity of a fluid flow.
