Help with Vectors: Force of Friction problem
Mr. Mcgoo pulls a sled with a force of 329.461 N at a 17° angle above the horizontal, and the problem requires finding the force of friction acting on the sled. Participants discuss the need to break down the pulling force into its horizontal and vertical components, emphasizing that the horizontal component is crucial for calculating the friction force. There is some confusion about the terminology, particularly regarding the concept of vector components and their directions. The sled is assumed to be on a level surface, and the friction force is expected to equal the horizontal component of the applied force. Accurate calculations using trigonometry are necessary to determine the friction force correctly.
LeonM
"Mr Mcgoo pulls a sled with several children on it at a constant speed. If he pulls with a force of 329.461 N at an angle of 17° above the horizontal, what is the force of friction on the sled?"
Not sure if i even drew the picture right(is it like a triangle, but it doesn't say hill, don't understand the whole "horizontal" thing), but i can't figure how to solve this.
I drew a picture(which may have been incorrect) and identified the Fρ(parallel force) as being 329.461 N and i need to find Ff. I also have the knowledge that Ff is the equal and opposite of Fρ.
Hi Leon welcome to PF!
Looks like perhaps the sled is being pulled along a level surface, and the pulling force of 329 N is applied at an angle 17 degrees above the horizontal. Wording is not fully clear, but that is how I would read it. What is the component of that pulling force in the horizontal direction?
Not sure what you mean by component? Do you mean direction, if so, I am not sure, just assuming east.
Yes, any vector directed in two dimensions can be thought of as having an influence in two different directions. That is, it can be thought of as having two parts. Each part of a two-dimensional vector is known as a component. If the sled is moving left to right (west to east), the force F, applied 17 degrees above the horizontal, can be broken up into its easterly and northerly components, using basic trig and the properties of a right triangle. What is the easterly component of F? What is the direction of the friction force? Is the friction force equal to the easterly component of F? Why?
Right, Right. So the east component would be 329.461 N, which would give you the adjacent side of 17°. After finding all the sides I will have my Fp which would be the hypotenuse, and Ff is equal or opposite Fp(my answer). If I am not mistaken?
First, I am not sure if you are describing the problem correctly. How exactly is it worded? I don't know why the problem would give an applied force accurate to the nearest thousandth of a Newton. The applied force is the hypotenuse. The horizontal component must be calculated.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
