Help with what is probably an easy question please. Pressure Problem
  • Thread starter Thread starter cdm1a23
    Pressure
To maintain the original pressure of a tire filled with air at 15°C and a gauge pressure of 220 kPa when the temperature rises to 46°C, a calculation shows that approximately 10% of the air must be released. The calculations utilize the ideal gas law, where the volume of the tire is assumed constant. The initial and final states are compared using the equation PV = nRT, resulting in the conclusion that n2 is 90% of n1. The method of keeping n in the equation is confirmed as correct, provided the tire volume remains unchanged. Overall, the approach and calculations appear accurate for the problem at hand.
cdm1a23
A tire is filled with air at 15 C and is at a gauge pressure of 220 kPa. If the air temperature goes to 46 C, what fraction of the original air must be released to maintain the original pressure?
Here is what I did:
15 + 273 = 288
46 + 273 = 319
PV = nRT
P1V1 = (n1)288
P2V2 = (n2)319
(n1)288 = (n2)319
(n1) * 288/319 = (n2)
288/319 = .90 so (n2) is 90 percent of (n1), and 10 percent should be removed.
Does this look right?
Thanks Very Much!
That all looks right to me. The only assumption we need to make for your method to be correct is that the volume of the tires does not change, which seems reasonable.
Thanks very much LeonhardEuler!
This is for class, and I still have time, so if anyone else can see a problem with it, please let me know.
Thank you.
Just to add one thing... is the method of keeping n in the equation as I did correct?
Thanks again.
