High school Calculus homework on series
snowlove
high school Calculus B/C class homework:
1) Find a Series for f(x) = \frac{1}{1+x} then find the interval of convergence.
i know that \frac{1}{1+x} = 1-x+ x^{2}-x^{3}+...+ -x^{n}+... -1<x<1
but then i don`t understand how can i use the result from 1) to find 2) answer? since you guy will teach me how to do 2) then do i just do the same thing for 3) ?
2) Using your result from 1) find a series for \frac{1}{1+x^2}
3) Using your result from 2) find a series for tan^{-1}x then use your series to approximate \pi to four decimal places. How many terms did you need?
Replace x by x2
For the third one, consider what d/dx(tan-1x) gives
thank you
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
