High temperature electrical insolator that repels carbon deposits
The discussion revolves around the search for materials that can withstand high temperatures (1250 C) in a CVI furnace while either repelling carbon deposits or reacting with them to form non-conductive compounds. The context includes considerations for electrical insulation and the prevention of short circuits in heating element supports.
  • One participant inquires about materials that can handle high temperatures and either repel or react with carbon deposits to prevent electrical conductivity.
  • Another participant suggests using a shroud around the support to shield it from carbon deposits, although acknowledges that this may not be effective if the carbon originates from a gas.
  • A third participant mentions that high voltage and extremely high voltage equipment often employs corrugated surfaces to increase the path length for electrical insulation and may have surface treatments that repel contaminants.
  • A participant provides details about the carbon deposit thickness observed over a two-day period and discusses the challenges of sealing at high temperatures while maintaining gas flow for protection.
  • There is a suggestion to direct nitrogen flow towards the supports as a potential solution, along with the idea of using a shroud to create an inert atmosphere.
Participants express various approaches and ideas, but there is no consensus on a definitive solution or material. The discussion remains open with multiple competing views and suggestions.
The discussion highlights the limitations of sealing methods at high temperatures and the challenges associated with maintaining an inert atmosphere while preventing carbon deposits.
Quince
Is there any material/s that will handle CVI furnace temperatures (1250 C) and will either repel carbon deposits or react with it to create a compound that is not electric conductive? Trying to contain power to the heating element without shorting it to the base/ground through heating element supports.
Not offhand. But can you but a shroud around most of the support length to shadow it? Of course if the Carbon is from a decomposing flowing gas this may not help much. A labyrinth seal at the open end of the shroud may be the next step.
(Here is an attempted sketch but it may not render correctly)
Code:
               ___________ shroud
element        |______________ to wall
suppoort-------|
               |__________
Cheers,
Tom
IIRC, HV & EHV pylon, transformer & switch-gear 'stand-offs' are corrugated to increase path length, but may also have a surface finish / treatment proven to repel muck.
Could be worth a look...
FWIW, even such do need jet-wash cleaning from time to time: My wife got stuck in a shopping centre lift when contract cleaners mistakenly sprayed the 'live' set at local grid station, tripped half the city...
Tom, the deposit IS from gas and about .003" (.076 mm) in a single 2 day run. I have nitrogen flowing to protect, but the main box will always bleed some gas. Hard to seal at that temperature without sinking the boat. Rebuilding the supports is a long, expensive and painful process. Finding a solution will be quite elegant and beneficial, maybe, to other applications.
Nik, I’ll have to find out what IIRC, HV, EHV and FWIW stand for.
Oops.
'If I Remember Correctly'
'high voltage'
'Extremely high voltage'
'for what its worth...'
Understood. Can you plumb the Nitrogen so it is aimed at the supports? Probably not cheap but maybe the cheapest.
As a last-resort possibility, consider the shroud approach with the Nitrogen delivered inside the shroud for a continuous inert atmosphere.
Interesting problem. please keep us updated.
Cheers,
Tom
  • · Replies 0 ·
10K
  • · Replies 0 ·
