Using an electrical device bought in France, in Canada
Using a camera charger bought in France in Canada requires checking the charger's voltage specifications. If the charger is rated for 100-240 V and 50/60 Hz, it can be safely used in Canada without issues. If it only supports 220 V, plugging it into a 110 V supply may prevent it from functioning, but it typically won't cause damage. Adapters or transformers can be purchased if necessary. Always verify the charger's input specifications to ensure compatibility.
fluidistic
I bought a camera in France and I want to use it in Canada. The main problem is the battery. To reload it (I think it's a lithium one but I'm not sure. I can check out if you need this info) I must plug it into the AC current supply at home. In France it works at a different frequency I believe than in Canada and the voltage is 220 V compared to the 110 V in Canada.
What happens if I directly plug the battery reloader into a Canadian home electrical supply? The device is made to work with 220 V and the French frequency.
My guess is that it simply won't work and will not damage anything.
I might think to just take my memory card and borrow a camera in Canada if I can't reload the battery without buying a transformer (110 V to 220 V).
What's the make and model of the camera? Most consumer electronics nowadays have DC supplies that take 100-250 V, and accept different cord ends to plug into the outlets in various countries.
Worse comes to worse, you can buy adapters at Futureshop or The Source (or the likes) that change the voltage.
Check the back of the battery charger (which I think is what you mean by "reloading" it...recharging?). If it says 100-240 V, 50/60 Hz it's a dual-voltage charger and can be used safely. If it doesn't, you'll need some sort of voltage transformer which can be bought at pretty much any electronics store for a reasonable price.
Most cameras don't have dedicated DC power sources and just come with USB cables and a battery charger wall wart.
Thanks to both. I just checked out the battery charger and it says "INPUT 100 V-240 V AC 50/60 Hz
0.1 A (100V) 0.06 A (240 V)
OUTPUT: 4.2 V----0.65 A."
So it seems I won't have any problem? Seems like it needs AC.
Out of curiosity, what would have happened if it could only work at 240 V and I plug it in a 120 V supply?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
