Hooke's Law and Centripetal Motion
The discussion revolves around calculating the spring constant k and the effective mass of a system using Hooke's Law and centripetal motion principles. A 0.20 kg mass causes a 9.50 cm elongation, while a 1.00 kg mass results in a 12.00 cm elongation. The initial calculations for weight and spring constant are critiqued for unit conversion errors, emphasizing the need to convert elongation from centimeters to meters. Participants suggest using the unweighted length of the spring to derive two equations for k and the equilibrium position. The conversation highlights the importance of clarity in problem statements and proper unit handling in physics calculations.
CAG0625
A 0.20 kg mass hangs vertically from a spring and an elongation below the support point of the spring of 9.50 cm is recorded. With 1.00 kg hanging on the spring, a second elongation of 12.00 cm is recorded. Calculate the spring constant k in Newtons per meter. (Note the equilibrium position is not 0.) Then at the elongation of 9.50 cm, a frequency of 300 rev/min is recorded. Then at elongation of 12.00 cm, frequency of 400 rev/min is recorded. Calculate the effective mass of the system in kilograms. (convert to SI. w=f*2pi/60 switches from rev/min to rad/sec.)
W=mg
W=-kd
W=(0.20kg)(980.35 cm/s^2) = 196.07N
W=(1.00kg)(980.35cm/s^2)=980.35N
196.07N=-k(0.095m)=-2063.89N/m
980.35N=-k(0.12m) = -8169N/m
Is that all correct and I do not know where to go from here.
kg cm/s^2 is not going to give Newtons. Better to convert the cm to m, not the other way around.
You are misreading the question. I'm not sure if it is misleading because it refers to 'elongation' when it means length, or maybe you are supposed to allow for the spring's own mass:
Your first two lines in 3 give you the force F for two different extensions x below the unweighted length.
You don't know x, but if you assume the unweighted length of the hanging spring is h then you have two values of x+h.
Using Hooke's Law you can get two independent equations in h and k. Then solve for h and k.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 36 ·
