Solve the Equilibrium of a Light Elastic String with Mass m
The discussion revolves around solving for the length AD in a system involving two elastic strings with different moduli of elasticity. The participant sets up equations based on the tensions in the strings and applies Hooke's law to relate the tensions to the extensions of the strings. They derive the equation 2x - 4y = l but express uncertainty about the missing distance between the fixed point and AD. The conversation highlights the need for clarification on the equilibrium conditions and the derivation of the tension relationship. Overall, the participant seeks guidance on completing the solution.
aurao2003
Hi
Can anyone please help with this question?
A light elastic string AB has natural length l and modulus of elasticity 2mg. Another light elastic string CD has natural length l and modulus of elasticity 4mg. The strings are joined at their ends B and C and the end A is attached to a fixed point. A particle of mass m is hung from the end D and is at rest in equilibrium. Find the length AD.
this is what I did
Let Tension AB is T2 and tension CD be T1. since system is at rest
T2-T1 = mg (Equation 1)
AD = l +x +y +l (Where x and y are the extensions of AB and CD respectively)
So, AD = 2l +x+y
Using Hookes law
T2 = 2mgx/l
Similarly, T1 = 4mgy/l
substituting the above into equation 1
2x-4y =l
This is as far as I can go. I wasn't given the distance between the the fixed point and AD. Am I missing something? Kindly comment.
Draw a free-body diagram for the particle of mass m. What does the diagram tell you about the tension T1?
Also, what is your justification for claiming T2-T1 = mg ?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
