Understanding Hook's Law and Compression of Springs
The discussion focuses on applying Hook's Law to determine how much a spring compresses under a force. When a 30 cm spring is compressed with a force of 100 N and a spring constant of 1000 N/m, the spring shortens by 10 cm. The original length of the spring is irrelevant because Hook's Law only considers the displacement from the spring's natural length. The negative sign in Hook's Law indicates that the force exerted by the spring opposes the direction of compression. Ultimately, the key takeaway is that the force exerted by a Hookean spring depends solely on the change in length, not the initial or final lengths.
Gear2d
If a person holds a 30cm spring and compress on it with a force of 100 N (where k = 1000 N/m), by how much is the spring shortened.
Hooks ' Law: F = -k* deltaX
The answer for this is 10 cm: 10 = -1000 * deltaX
Why doesn't the length of the original spring matter here? Also, how does the "-" sign affect Hook's Law here in this problem.
Let's turn it around, why do you think that the unstretched spring should matter? Does an unstretched spring exert a force?
The negative sign simply indicates that the force exerted by the spring is in the opposite direction to the compression/extension.
What you are saying is that here they are looking for how much the spring was compressed by, not the final length of the spring after compression (which is 20cm?).
Yes, the force exerted by a [hookean] spring depends only on the displacement from it's natural length. The 'delta x' in Hooke's law represents the change in length of the spring, the initial and final lengths of the string are irrelevant.
Thanks Hootenanny
