Hoolomorphic functions stretching angles
  • Thread starter Thread starter sin123
    Angles Functions
The discussion centers on the behavior of holomorphic functions at critical points, specifically how these functions stretch angles. It begins with a reference to Taylor's Theorem, emphasizing that if a critical point z0 has a non-zero m-th derivative, the function f(z) will multiply angles by m. Participants explore the connection between Taylor series coefficients and angle transformations, ultimately realizing that higher-order terms do not affect the tangent angle at z0. The conversation shifts to using polar coordinates to simplify the analysis, confirming that the angle transformation is indeed n*theta. The conclusion highlights that while a rigorous argument is desired, a conceptual understanding suffices for this problem.
sin123
If z0 is a critical point of f(z), and m is the smallest integer such that f(m)(z0)=!= 0, then the mapping given by f multiples angles at z0 by a factor of m.
Hint: Taylor's Theorem
I don't even know where to start. Any hints would be appreciated.
Start by writing down the taylor expansion. What does the given condition tell you about the coefficients of the series?
It tells me that the first couple of coefficients are zero. But what's the connection between the Taylor series of a function and the angles in its image?
Yes, it's telling you that you can write the taylor series as f(z)=a_m*(z-z0)^m*(1+...) where the '...' stuff becomes small as z->z0. How do angles of straight lines through the origin behave under the function f(z)=z^m?
I am not sure.
Suppose f(z) = z^n, and g is a line of slope m, say g(t) = t + m t i. Then
f(g(t)) = (t + m t i)^n = \Sigma \left( \begin{array}{c} n \\ 2k \end{array} \right) (-1)^k m^{2k} t^n \, + \, i \, \, \Sigma \left( \begin{array}{c} n \\ 2k+1 \end{array} \right) (-1)^{k} m^{2k+1} t^n
Interpreting this as a parametrized curve in R^2, I would get
x(t) = \Sigma \left( \begin{array}{c} n \\ 2k \end{array} \right) (-1)^k m^{2k} t^n
y(t) = \Sigma \left( \begin{array}{c} n \\ 2k+1 \end{array} \right) (-1)^{k} m^{2k+1} t^n
Their derivatives with respect to t are
\frac{dx}{dt} = n \Sigma \left( \begin{array}{c} n \\ 2k \end{array} \right) (-1)^k m^{2k} t^{n-1}
\frac{dy}{dt} = n \Sigma \left( \begin{array}{c} n \\ 2k+1 \end{array} \right) (-1)^{k} m^{2k+1} t^{n-1}
Resulting in a slope of
\frac{dx}{dy} = \frac{\Sigma \left( \begin{array}{c} n \\ 2k \end{array} \right) (-1)^k m^{2k}}{\Sigma \left( \begin{array}{c} n \\ 2k+1 \end{array} \right) (-1)^{k} m^{2k+1} }
Does this look right? And if it does, does this relate to m in any obvious way?
Yeow. Nice try. But you are taking the long way around! Write the line in polar notation r*exp(i*theta) where r is variable and theta is the constant angle.
Hahaha, yes, it should have occurred to me that I am in complex analysis and not multivariable calculus :)
Let's see. In this case g(r) = r exp(i theta), and f(g(r)) = r^n exp(i n theta). Now my angle is n*theta. Makes sense.
By pre- and post-composing with translations, I can WLOG assume that I am interested in a pair of lines through the origin, and that f(0) = 0. But why do higher-order terms not impact the angle?
The angles they are talking about are the tangent angles of curves through the point z0. You really just need the angle in the limit as z->z0. You can make the higher order terms as small as you want relative to the first term. The higher order terms will make lines transform into curves away from z=z0, but they won't affect the tangent angle.
It makes sense intuitively. I am still struggling to come up with a rigorous argument why higher-order terms don't matter - I guess I am not sure how tangent angles are defined in complex-analysis-land to begin with. But at least now I get the idea for the proof. I can probably figure the rest out on my own.
Thank you very much for your help!
I wouldn't worry about making this overly rigorous. The result isn't THAT interesting or fundamental. I would feel free to do some hand waving, as long as you communicate the idea. That's about the only interesting part.
