How are atomic radii and H-bond strength related?
The discussion centers on the relationship between atomic radii and hydrogen bond strength, particularly in the context of boiling points of HF and HCl. HF has a higher boiling point than HCl despite HCl's larger molar mass due to fluorine's greater electronegativity, resulting in stronger hydrogen bonds. The smaller atomic radius of HF means that the hydrogen atom is closer to the electronegative fluorine, making it harder to break the bond. This relationship highlights how atomic size influences intermolecular forces, particularly through dipole moments. Understanding these concepts is essential for grasping the underlying principles of molecular interactions in chemistry.
Saladsamurai
I answered a question that my professor asked: "Why is the boiling point of HF much higher than that of HCl even though HCl has a larger molar mass?"
The answer had to do with F being more electronegative than Cl and thus making stronger H-bonds.
He also said on an aside that it all boils down to atomic radii. What did he mean by that? How are the two correlated?
Thanks!
Casey
Thanks!
Casey
A good rule to remember is that H-bonds(such as H-O, H-F, and H-N) > dipole-dipole bonds (such as H-Cl in this case). Another way to look at this is by the atomic radii. The radii for H-F is smaller than H-CL, this makes it much harder to break away due to the Hydrogen being so close to the electronegative Fluorine.
An example for atomic radii, I guess, would be to picture yourself holding someone's hand. Would it be harder to break you two apart while you're closer together or father apart?
Thanks!
Casey
Study the equation for dipole moment - it is somewhat related to the differences in electronegativity as well as the distance between the charges - the greater the dipole moment within a molecule the greater the intermolecular attraction between molecules.
I will look into that. This is a Materials Science course, so we never really covered this stuff explicitly.
I will do some Wiki-ing :smile:
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
