How Can I Calculate Reciprocal Lattice Vectors for a 2D Lattice?
The discussion revolves around calculating the reciprocal lattice vectors for a 2D lattice, specifically for a Si(001) structure with a (2x1) reconstruction. The original poster presents their attempts to apply 3D reciprocal lattice vector formulas to a 2D context, leading to confusion regarding the calculations and the significance of certain terms.
  • The original poster attempts to use the 3D formula for reciprocal lattice vectors but encounters issues when applying it to a 2D lattice, particularly with the denominator resulting in zero. Other participants suggest alternative approaches and question the validity of the original poster's calculations.
Participants are actively engaging with the problem, offering corrections and alternative perspectives. Some guidance has been provided regarding the evaluation of the numerator and the implications of the denominator being zero, but there is still uncertainty about the overall significance of these results.
There is an ongoing discussion about the appropriateness of using 3D formulas in a 2D context, and participants are questioning the assumptions made in the calculations. The original poster expresses confusion about the results and seeks clarification on the underlying concepts.
jonesj314
Si(001) has the following lattice vectors in a (2x1) reconstruction [tex]\vec{a'_1} = \vec{a_1} + \vec{a_2}[/tex] [tex]\vec{a'_2} = -0.5 \vec{a_1} + 0.5 \vec{a_2}[/tex]
Calculate the reciprocal lattice vectors of the reconstructed unit cell, [itex]\vec{b'_1}[/itex] and [itex]\vec{b'_2}[/itex] in terms of [itex]\vec{a_1}[/itex] and [itex]\vec{a_2}[/itex].
I have been using the formulae for finding reciprocal lattice vectors in 3D, i.e
[tex]\vec{b'_1} = 2 π \frac{(\vec{a'_2} ×\vec{a'_3})}{\vec{a'_1}. (\vec{a'_2} × \vec{a'_3})}[/tex]
and the usual permutations for the other 2 reciprocal vectors
Since I'm trying to do this for a 2D lattice I'm running into problems. If I treat [itex]\vec{a'_3}[/itex] as simply being the z unit vector, then i find the numerator to be [itex]\vec{b'_1} = 2π (0.5 \vec{a_1} - 0.5 \vec{a_2})[/itex] is this correct for the numerator?? (it's orthogonal to [itex]\vec{a'_2}[/itex] as I was expecting)
however, using this method I find the denominator to be zero since,
[tex]\vec{a'_1}. (\vec{a'_2} × \vec{a'_3}) = (\vec{a_1} + \vec{a_2}) . (0.5\vec{a_1} - 0.5\vec{a_2} )[/tex]
and this dot product equals zero.
What am I doing wrong? Any help appreciated
I get [itex]\vec{b'_1} = 2π (0.5 \vec{a_1} + 0.5 \vec{a_2})[/itex]
And permuting the terms in the triple product try (a1' x a2')°a3'; but the cross product is parallel to a3' (which is OK, 'cause it is a dot product), and a3' is a unit vector so the volume is just |a1' x a2'|= area of the parallelogram with sides a1', a2'.
Hi, thanks for the reply. You're right, I evaluated the numerator incorrectly.
I still don't understand the significance of the denominator. Why do I get zero? Would permuting the triple product to the form you suggest give a different answer?
Quite confused as to what this should be.
It gives the same answer: I just shifted the form to make the result obvious, and simple to compute. Your product a2' x a3' is incorrect ... same error as with b1.
The magnitude is 1.
oh of course :) thank you! All makes sense now
  • · Replies 20 ·
11K
