How can I calculate the compression of a support column under a heavier weight?
The discussion centers on calculating the compression of a support column under varying weights using Hooke's Law, represented by the equation F=KX. The initial compression of 2.46 x 10^-4 m under a weight of 5.42 x 10^5 N leads to the determination of the spring constant K as 2,203,252,032.52 N/m. When applying this K value to a new weight of 4.8 x 10^6 N, the calculated compression is confirmed to be 0.0022 m (2.2 x 10^-3 m). Both methods of calculation yield the same result, affirming the correctness of the approach as long as the column remains elastic.
  • Understanding of Hooke's Law (F=KX)
  • Basic knowledge of elastic deformation
  • Ability to perform unit conversions and scientific notation
  • Familiarity with solving algebraic equations
  • Study the implications of elastic vs. plastic deformation in materials
  • Learn about the properties of materials under stress and strain
  • Explore advanced applications of Hooke's Law in engineering
  • Investigate the effects of different materials on compression calculations
Students in physics or engineering, mechanical engineers, and anyone interested in material science and structural analysis will benefit from this discussion.
kkmonte
A support column is compressed 2.46 x 10^ -4m under a weight of 5.42 X 10^5N. how much is the column compressed under a weight of 4.8 X10^6N?
F=KX
By using that equation, I get 542000 = .000246K
Solve for K, and I get a huge number, 2,203,252,032.52
Then by using that number as my new K, and solving for the compressed distance with the new weight, I get 0.0022 m.
Is that the right answer?
Similarly, I figured I could just make a ratio proportion of:
.000246....X
542,000....4,800,000
Which also gives me an answer of 0.0022 m (2.2 X 10^ -3). Is this correct?
Yes, either method gives you the correct solution, as long as the column is still behaving elastically in accordance with Hooke's law.
Thanks Jay, when I first did this problem, I was looking at the answer of 2.2e-3 and shaking my head going how can this thing compress less when there is a heavier weight on it? However it wasn't after I was typing it in the computer that I realized that the first compression is 2.46e-4, and I went, duh. =)
Thanks for letting me know I'm correct.
Ken
9K
