How to Prove (∂U/∂V)P = TCV/V for a Perfect Gas?
To prove (∂U/∂V)P = TCV/V for a perfect gas, begin with the internal energy equation, U, expressed in terms of temperature and volume. The discussion suggests using the differential form dU = CvdT, which relates changes in internal energy to temperature changes at constant volume. Expanding U in terms of temperature and volume will clarify the relationship, leading to the desired equation. It is emphasized to remember that this involves a partial derivative and to conclude with QED. This approach provides a structured method to derive the required proof.
fgr
Hi! I need to prove that:
(∂U/∂V)P = TCV/V
For a perfect gas.
But I don't know start. Can you help me please?
How about starting with an equation for what U is?
Obviously, try expanding the equation of what U really is in terms of TC/V. It's a bit long, but eventually the ans becomes clear.
If ur really stuck, instead of copying an answer, try reading this-http://http://www.colby.edu/chemistry/PChem/notes/Ideal1st.pdf
Oh, and don't forget that it's a partial derivative...and to write QED at the end. cheers :)
Start out with dU = CvdT for an ideal gas.
Chet
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
