How to Prove (∂U/∂V)P = TCV/V for a Perfect Gas?
To prove (∂U/∂V)P = TCV/V for a perfect gas, begin with the internal energy equation, U, expressed in terms of temperature and volume. The discussion suggests using the differential form dU = CvdT, which relates changes in internal energy to temperature changes at constant volume. Expanding U in terms of temperature and volume will clarify the relationship, leading to the desired equation. It is emphasized to remember that this involves a partial derivative and to conclude with QED. This approach provides a structured method to derive the required proof.
fgr
Hi! I need to prove that:
(∂U/∂V)P = TCV/V
For a perfect gas.
But I don't know start. Can you help me please?
How about starting with an equation for what U is?
Obviously, try expanding the equation of what U really is in terms of TC/V. It's a bit long, but eventually the ans becomes clear.
If ur really stuck, instead of copying an answer, try reading this-http://http://www.colby.edu/chemistry/PChem/notes/Ideal1st.pdf
Oh, and don't forget that it's a partial derivative...and to write QED at the end. cheers :)
Start out with dU = CvdT for an ideal gas.
Chet
