- 23,706
- 5,921
Ouch!Bystander said:Okay, maybe it is one word ... Chet, chemical engineers are supposed to know these things.
I don't mean to belabour this, but it does seem to be a blind spot in common physics/thermo training. What happens to liquid water exposed to the air (wet bulb temp, evaporative cooling) is not a very different concept, and is discussed in quite a bit of detail in the courses I took. But mixtures of ice and liquids are not discussed (that I can recall). Per Bystander's point, my first exposure to it was on the practical side, making homemade iced cream with my grandparents. So it was something I took for granted long before I had any understanding of why it happened.Chestermiller said:Unfortunately, it was not so obvious to naive me (and many other mere mortals). At least at the beginning, it wasn't obvious to me that, as the ice melted, its temperature would be dropping.
Thanks. You started with more ice when you included the heat of mixing so I can't compare it exactly, but it looks the impact of the heat of mixing was pretty small. That, I expected. What I didn't expect was how much ice was melting and as a result, how much dilution there was. Of course, I also didn't look up the freezing point of ethanol prior to starting to make predictions...Chestermiller said:I completed a calculation with the heat of mixing effect included. The heat of mixing data was somewhat incomplete, and I had to use my best judgment at filling in the blanks. The initial state was a mixture of 44 g EtOH, 56 g water at 20 C, and 150 g ice at 0 C.
As best I could estimate, the final state was a mixture of 44g EtOH, 146 g water, and 60 g ice, all at -14 C.
[previous, without mixing]
Initial state:
100 gm alcohol/water solution, 44% alcohol mass percent at 20 C
100 gm ice at 0 C
Final State:
155 gm alcohol/water solution, 28% alcohol at -18 C
45 gm ice at -18 C
That's the key. Those of us who got to make made ice cream when we were kids are familiar with process. In that case it was ice and salt - to generate the extra cold conditions needed to get the mixture to form ice cream.Bystander said:No one's made ice cream?!
If you look at post #70 in this thread, DrStupid alludes to fractional crystalization. The frozen material will be pure water..Scott said:I don't believe the equilibrium condition has been fully explored. In final equilibrium there will be a liquid alcohol/water mix and a solid alcohol/water mix
That's the "jacking," a popular separation method used in the past. History of science is another hobby of mine --- didn't think this was that forgotten, but that's what I get for thinking and chewing gum.jbriggs444 said:If you look at post #70 in this thread, DrStupid alludes to fractional crystalization.
I agree with jbriggs444 in post #163 on this. Apparently you hadn't actually seen the phase diagram for EtOH/water when you made this statement..Scott said:I don't believe the equilibrium condition has been fully explored. In final equilibrium there will be a liquid alcohol/water mix and a solid alcohol/water mix, and those alcohol/water ratios will not be the same. And, of course, the temperature will be the same throughout.
jim hardy said:I think of it backward. (for me that comes natural )
We usually think of ice warming up to its melting point which we all know is 32F..
But what happens is ,
The drink cools down to its freezing point...
A good Gin & Tonic will frost the glass
So, are you saying that the ice has to start out below 0 C?Jon B said:]How can ice cool an alcoholic drink below 0°C? Answer: When the ice is massive enough and cold enough to bring the beverage from its present temperature to a temperature below 0°C. Remember, the quality of the answer is based on the quality of the question.
The ice does not have to be cold enough, that's the main result we established over the last pages. It can start at 0°C.Jon B said:How can ice cool an alcoholic drink below 0°C? Answer: When the ice is massive enough and cold enough to bring the beverage from its present temperature to a temperature below 0°C. Remember, the quality of the answer is based on the quality of the question.
