How did my earphones fix themselves?
  • Thread starter Thread starter frixis
The earphones initially had a malfunction where one side wouldn't work unless the jack was partially inserted, suggesting an intermittent bad connection. When the user opened the earphones and connected the red and green wires, sound was restored in both earphones, but this was likely due to shorting the channels together. After re-taping the wires, the earphones surprisingly continued to work without any direct connections. This indicates that the issue may be an intermittent open circuit, where slight movements in the wires can restore the connection temporarily. Overall, the situation highlights the complexities of earphone wiring and connections.
frixis
ok my earphones weren't working properly..
sony ericsson.. i had two sets of the headset and earphone pair..
anyhoo one of the earphones wudn't work if they were properly fixed in the jack but if i fixed the pin thingi lightly in the jack both wud work..
so i decided to open my earphones... um.. that place where all the wires are connected.. anyhoo there were 3 wires, red blue and green so i touched the ends of the red and green together and there was sound in both earphones
and then i taped it that way..
but today i untaped it all and none of the wire ends are touching now and i can still hear in both earphones...
can someone explain this!
It's magic.
I seems that you have an intermittent bad connection on one channel of your phones. Often when you only loosly (or half way) plug a stereo jack into a socket it shorts L and R channels together so I guess that's what was happening there. Note that you might hear something in both ears but its the same channel in both so not proper stereo.
Most likely the same when you shorted the two wires inside your earphones. My only guess as to why it's now working without the short is that the open-circuit is intermittent and just moving the wires around has caused it to make connection once more.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
