How Do Capacitors Charge in a Circuit with Multiple Batteries?
The discussion revolves around a circuit containing three capacitors (C1, C2, C3) connected to multiple batteries with specified voltages. The original poster seeks to determine the charge on each capacitor once equilibrium is reached, using Kirchhoff's rules and the relationship between voltage, charge, and capacitance.
  • The original poster attempts to apply Kirchhoff's rules to analyze the circuit but expresses uncertainty about their approach and the correctness of their equations. They question the setup of their equations regarding voltage drops across the capacitors.
Some participants note the absence of a circuit diagram, which complicates the analysis. The original poster has provided equations but is unsure about their validity. There is an ongoing exploration of the correct application of Kirchhoff's rules and the relationships between the charges on the capacitors.
The discussion is hindered by the lack of a visible figure representing the circuit, which is crucial for understanding the configuration and interactions of the components involved.
sabak22
Three capacitors C1–C3, all initially uncharged, are placed in the circuit show above. The capacitances are C1=15.2 μF, C2=9.8 μF, C3=4.4 μF, and the battery voltages are V1=20 V, V2=20 V, V3=5 V.
What is the magnitude q1 of the charge on capacitor C1 once equilibrium has been established?
What is the magnitude q2 of the charge on capacitor C2 once equilibrium has been established?
What is the magnitude q3 of the charge on capacitor C3 once equilibrium has been established?
V=Q/C
I1+I3=i2
I tried applrying the kirchhoff's rule, but i don't know where to go with it... i don't even know if i am write or not.
V1+Q1/C1 + Q2/C2+V2=0
V3+Q2/C2+V2+Q3/C3=0
No figure is visible, so it's impossible to help you.
really sorry about that. I didnt realize
sabak22 said:
I tried applying the Kirchhoff rule, but i don't know where to go with it... i don't even know if i am write or not.
V3+Q2/C2+V2+Q3/C3=0
For the loop with V1+Q1/C1 + Q2/C2+V2=0: Assuming the voltage drops are for traversing the loop in a Clockwise sense, there is a voltage drop across the capacitors. This equation should be:
V1 - Q1/C1 - Q2/C2 + V2=0 .​
Similarly, the signs for the voltages across the capacitors in the other loop equation should also be changed.
Additionally, you have Q1 + Q3 = Q2, because I1 + I3 = I2 .
Plugin all the values, do some algebra and see what you get.
  • · Replies 19 ·
9K
