How Do I Apply F=ma to Solve These Physics Problems?
  • Thread starter Thread starter idriveatc
    Law Newton's law
Understanding how to apply F=ma in physics problems involves identifying the correct variables and equations. For the baseball question, the mass is given, but the acceleration must be calculated using kinematic equations, specifically v_f^2 = v_0^2 + 2ad, where initial and final velocities and distance are known. In the race car scenario, the driver experiences g-forces that can be calculated by determining the acceleration from the distance and time, and then using F=ma to find the force exerted on the tires. It's crucial to differentiate between mass times velocity and mass times acceleration when solving these problems. Mastering these concepts will enhance problem-solving skills in physics.
idriveatc
Hey, i been trying to ask all my friends and trying to read the book over and over. I am having problems with physics, its really hard! I have some questions that I am stuck at. I got the basics that F=ma but can someone help me get which equations to use for these questions? Thank you, i have the answers to the questions but i would like to know how to do them thank you again
a 0.140 kg baseball travels at 35 m/s that strikes the catchers mitt that brings the ball to a stop. It recoils backward at 11.0cm. What is the average force applied by the ball on the glove. I used the basic law and found force of the baseball is 4.9N now where do i input the 11cm?
a race car can finish a 402 track in 6.40seconds from rest, how many g's does the driev feel? if combined with mass of the driver and race car is 485kg what horizontal force must the road exert on the tires. I am really stuck on the how many g's does he feel and what force is exert on the tires.
i don't need the answers, just need help on how do i go about analyizing which equations to use for questions. THANK YOU!
For the first question: remember that f=ma. You tried to find a force by multiplying .14kg by 35m/s, which is mass times velocity, not mass times acceleration.
To do f=ma you need to know the mass and the acceleration the ball undergoes. You already know the mass because it's explicity given as .14kg. The acceleration is the tricky part. The ball is traveling toward the mitt at 35 m/s and then, over the course of 11cm (.11m) it is brought to 0 m/s. So what kinematic equation do you know that will give you the acceleration if you know 1) initial velocity, 2) final velocity, and 3) distance moved ?
a=v(initial)-v(final) / distance?
I'd use v_{f}^2 = v_{0}^2 + 2ad
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
