How do I find the frequency of oscillation for a damped harmonic oscillator?
To find the frequency of oscillation for a damped harmonic oscillator, the equation x'' + (c/m)x' + (k/m)x - mg = 0 is established, with corrections noted for the mg term, which does not affect the frequency. The system is identified as under-damped, allowing for oscillations, which are characterized by a sinusoidal function combined with an exponential decay. The characteristic equation is derived as r^2 + (c/m)r + (k/m) = 0, leading to the identification of k in terms of a, m, and g. The final frequency can be calculated using the quadratic formula, confirming the solution process. Understanding these concepts is essential for accurately determining the frequency of oscillation in this context.
Slightly
The terminal speed of a freely falling object is v_t (assume a linear form of air resistance). When the object is suspended by a spring, the spring stretches by an amount a. Find the formula of the frequency of oscillation in terms of g, v_t, and a.
the linearly damped force = -cx'
I started by writing the equation,
x'' + cx'/m + kx/m - mg = 0
Is this the correct way to start the problem and where would I go to next? I know that undamped frequency is equal to sqrt(k/m) but I'm not sure what to do with the equation. I'm stuck!
Almost. In your "mg" term, you forgot to divide by m like you did in your other terms.
Perhaps more importantly though, this mg is a uniform force across all x and it does not depend on x or any of its derivatives.
I think it might be fine to simply remove the "mg" term altogether. It doesn't affect the frequency of oscillation, in this problem. It will affect the center of oscillation, but you're not asked to find that. So if I were you I'd just get rid of it.
Can you express k in terms of a, m and g?
So at the moment, you have a second order, homogeneous, linear, differential equation with constant coefficients. Single solutions of this type of equation come in the form x(t) = Ae^{\lambda t} The general solution may involve the linear sum of two, single solutions. (Here, \lambda can be, and generally is, a complex number.)
The first step in solving that is to write down its characteristic equation. Then find the roots of the characteristic equation.
You might wish to consult your textbook/course material on how to solve such differential equations. If not, even a quick Google search on "second order, homogeneous, linear, differential equation with constant coefficients" should produce all you need.
Can you explain to me why you came to this conclusion? How is this system under-damped?
I never said it was necessarily an imaginary number. Just a complex number (all real numbers are also complex).
That's funny.
So when I get the solution to the DE, where will the frequency come from?
Slightly said:
That's funny.
The fact that "frequency of oscillation" was even mentioned, I take that as implying the system is under-damped. I mean, if the system were critically damped or over-damped, there wouldn't be any oscillations at all.
An under-damped system has a sinusoidal function associated with it (like sine or cos). And in the case of a damped harmonic oscillator, it involves the sinusoidal function multiplied by an exponentiation function. It might be helpful to recall \cos{ \left( \omega_1 t \right)} = \frac{1}{2} \left( e^{i \omega_1 t} + e^{-i \omega_1 t} \right). Here, \omega_1 is an angular frequency (having units such as RAD/s).
So you might want to put the general solution in a form like x(t) = A e^{- \alpha t} \left( e^{ i \omega_1 t} + e^{- i \omega_1 t} \right)
I went through the DE and was able to obtain the characteristic equation to be
r^2+cr/m + k/m = 0
I said k = - mg/a
and c = mg/v_t
so... r^2+gr/v_t - g/a = o
In this case, can I assume r is the frequency?
so, using the quadratic formula,
r = -g/2v_t +/- sqrt(g^2/(4v^2)+ g/a) is this right?
I was able to figure it out! Thanks.
Great! :smile:
