How do I know what the internal resistance of a battery is in a diagram?
To determine the internal resistance of a battery in a circuit diagram, it is conventionally represented by a resistor labeled "r" adjacent to the battery. The terminal voltage can be calculated using the formula V = IR, where V is the battery voltage minus the voltage drop across the internal resistance. Understanding that the 1 ohm resistor next to the battery signifies internal resistance is crucial for solving related problems. This labeling is a standard practice in circuit diagrams. Recognizing these conventions simplifies the analysis of battery performance in electrical circuits.
chiddler
I am trying to find terminal voltage of the batteries in the circuit shown.
V = IR
The solution manual says that it's the battery voltage, v, minus the voltage drawn from the resistance v = I * R. I understand this.
I do not understand how I'm supposed to know that the 1 ohm resistor adjacent to each battery corresponds to the battery's internal resistance. I would very much appreciate help with this. Thank you!
It's labeled with "r". There's no rhyme or reason to this; it's just convention that whenever you see a resistor labeled "r" beside a battery, you should assume that it's internal resistance.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
