How do I simplify this fraction?
  • Thread starter Thread starter polishdude20
    Fraction Simplify
The discussion focuses on simplifying a complex fraction involving multiple rational expressions. Participants emphasize the importance of finding a common denominator, which is identified as p(p+4)(p-4). One user initially miscalculates a fraction, leading to confusion, but later clarifies their understanding after further consideration. The conversation highlights the need for careful factoring and multiplication of terms to achieve the simplest form. Ultimately, the correct approach involves using the lowest common denominator to combine the fractions accurately.
polishdude20
Simplify the following expression by rewriting it as a single simple fraction in simplest form:
not much just factoring and solving for P
I tried to factor the fractions by multiplying the denominators with the numerators and after much writing on paper I came up with : (p+5)/(p^2-16) , I also came up with : (fp^2+p)/(p^3-16p)
I'm stumped here as to how much I have to factor or simplify or even even I did it right?
You are right in the sense that you need a common denominator..
Would this help?
5/(p+4) - 5/p(p-2) + 4/(p-4)(p+4)
it's supposed to be "5/p(p-4)" but I've done it with ALOT of writing, this stuff fills up your page fast doesn't it?
Well if you got it, who cares? Haha
It can. But 5/(p(p-4)) isn't right. Putting p=1 in your original expression I get 12/5. Putting p=1 into 5/(p(p-4)) gives -5/3. That isn't right. Is there a typo?
I don't know dick but I got the answer figured out after doing some more thinking, if you guys want to see a solution just wolfram alpha it.. I didn't do it that way though..
Well I hope you didn't get 5/(p(p-4)) as the answer, because it's not right!
Lowest Common Denominator is p(p+4)(p-4).
Multiply each rational term by 1 using the suitable factors from the LCD,
\frac{5}{(p+4)}\frac{p(p-4)}{p(p-4)}-\frac{5}{p(p-4)}\frac{p+4}{p+4}+\frac{4}{(p+4)(p-4)}\frac{p}{p}
Perform the needed multiplications for the numerator and look for any further simplifications.
nono! I said that because somone else wrote the wrong thing and stuff.
