How do I solve these physics problems?
  • Thread starter Thread starter Serena_Greene
    Brain
The discussion focuses on solving two physics homework problems involving static friction and projectile motion. For the first problem, the normal force must account for the horizontal force's component acting perpendicular to the incline, which affects the calculation of the coefficient of static friction. The second problem emphasizes the relationship between work, force, and distance to determine the arrow's speed when the force is tripled. Clarifications provided help in understanding the correct approach to both problems. The insights shared lead to a resolution of the initial confusion regarding the calculations.
Serena_Greene
I need some direction with two homework problems.
1) A 215kg crate rests on a surface that is inclined above the horizontal at an angle of 26.1 degrees. A horizontal force, 528 N, is required to start the create moving down the incline. What is the coefficient of static friction between the crate and incline?
I know that static friction = Frictional Force / Normal Force
Is the normal force for the crate = 215 * 9.8 * sin 26.1
Is the force that is required to move it down the ramp = 528/cos 26.1
I'm getting .63429 for the static friction, but the answer is supposed to be 0.884
So what am I missing?
2) An arrow, starting from rest, leaves the bow with a speed of 26.4 m/s. If the average force exerted on the arrow by the bow was increased 3 times and the arrow was accelerated over the same distance, then with what speed would the arrow leave the bow?
I'm thinking that I would use two equations that solve for x and set them equal to each other, but I don't think I have enough information.
Thanks,
Serena
Serena,
For the first problem, the normal force will be reduced since the applied horizontal force has a component normal to the incline and must be accounted for.
In the second problem, recognize that work = force X distance and that is what imparts energy (or speed) to the arrow.
Thanks, it works now.
