How Do You Calculate Spring Constant with Friction Involved?
To calculate the spring constant with friction involved, the total distance the object moves after first touching the spring must be determined, which involves understanding the work done by friction. The energy stored in the spring when the object compresses it is derived from the initial kinetic energy minus the work done against friction. The spring constant can be found using the relationship between the energy stored in the spring and the displacement, applying the formula for work done on a spring. The average force during compression is calculated to assist in determining the energy stored. Understanding these principles allows for the correct calculation of the spring constant in the presence of friction.
rileyjah
Friction/Springs/HELP!
An object of mass m=2.6 kg is traveling on a horizontal surface. The coefficient of kinetic friction between the object and the surface is µk=0.16. The object has speed v=0.65 m/s when it reaches x=0 and encounters a spring. The object compresses the spring a distance d/2, stops instantaneously, and then travels back to x=0 where it stops completely. Eventually you will be asked to find the spring constant, k.
1.What is the total distance, d, that the object moves after first touching the spring?
2.When the object reaches d/2 and stops instantaneously, what is the energy stored in the spring?
3.What is the spring constant, k, of the spring?
I just tried to post w/ my entire attempt at a soln ad somehow lost it- so here's a quick version.
1. I got this correct- Wfriction=mv^2/2=-mgukd, solve for d gives correct answer
2. KEspring+Espring=KEi+ Wfriction
Espring= KEi- KEspring+Wfriction=.5mv2-0-mgukd
not correct answer, this is where I feel very confused
3. Espring=-k*d ?
DO I have to use Kf+Uf+deltaEth=Ki+Ui+Wext to solve this problem beacuse friction is non-conservative... if so how?
Ok, I know how to get 2. So how do I get the spring constant, F=-k*X, but what is F??/
The work required to compress a spring is (1/2)kx2 where x is the compression in meters and k is the spring constant. If you figured the energy to compress the spring then you can solve for it, yes?
the energy stored in the spring is equal to the work done on it, (F_avg)(displacement). F is 0 when it just starts to compress, and F is kx when it's compressed to its maximum. So calculate (F_avg), and multiply it by the spring displacement, to get the stored energy, a well known equation.
Thank you all I got it now ;)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
