How Do You Calculate the Effective Mass of an X-ray Photon?
To calculate the effective mass of an X-ray photon, the momentum can be determined using the formula p = h/λ, where h is Planck's constant and λ is the wavelength. For a 0.33 nm X-ray photon, the momentum is calculated to be 2.009E-24 kg·m/s. The effective mass can be derived from the relationship mc² = p·c, leading to the conclusion that the effective mass is related to the momentum and the speed of light. The discussion emphasizes the importance of understanding the relationship between momentum and mass in the context of photons. This approach simplifies the calculation of effective mass for X-ray photons.
whitetigerboy56
OK ... i figured out the momentum, however i need help with find the mass. anyone know how?
What is the momentum of a 0.33 nm X-ray photon?
2.009E-24 kg · m/s
What is its effective mass?
_________ kg
thanks :biggrin: :biggrin:
h\frac{c}{\lambda}=mc^{2} is all u need to know...
Daniel.
Dude... Thanks
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
