How Do You Calculate the Launch Velocity Components in a Football Field Goal?
  • Thread starter Thread starter Miss1nik2
To calculate the launch velocity components for a football field goal, the ball experiences an acceleration of 229 m/s² for 0.0300 seconds, resulting in horizontal and vertical components of velocity, Ax = 146.28 m/s and Ay = 176.19 m/s. The discussion also transitions to a related problem involving a rocket launched at 63.0 m/s at a 37.0° angle, aiming to determine how much it clears an 18.1 m high wall located 32.0 m away. Participants confirm calculations for the rocket's horizontal and vertical components, arriving at Vox = 50.31 m/s and Voy = 37.91 m/s, and subsequently calculating the height at that distance. The final result indicates the rocket clears the wall by 4.16 m, showcasing successful problem-solving collaboration.
Miss1nik2
Can someone PLEASE help me with this problem??
In a football game a kicker attempts a field goal. The ball remains in contact with the kicker's foot for 0.0300 s, during which time it experiences an acceleration of 229 m/s2. The ball is launched at an angle of 50.3 ° above the ground. Determine the (a) horizontal and (b) vertical components of the launch velocity.
I figured out that Ax=146.28 and Ay= 176.19, but I am stuck after that.
well you did the hard part...
I would've found the velocity first then broken it down into components, but I suppose your way is just as good...
you got t = .03 s
you got Ax = 146.28 and Ay = 176.19
well, Velocity = (acceleration) X (time)
so find Vx and Vy
I think I got it. Thanks.
But now I need help with...
A rocket is fired at a speed of 63.0 m/s from ground level, at an angle of 37.0 ° above the horizontal. The rocket is fired toward an 18.1-m high wall, which is located 32.0 m away. The rocket attains its launch speed in a negligibly short period of time, after which its engines shut down and the rocket coasts. By how much does the rocket clear the top of the wall?
I got Vox=50.31 and Voy=37.91. And I got, at 32 m the time is t=.64s. Then y=22.26. Then subtract 18.1 and I got 4.16.
...well in that case I don't think u need help at all, because I got the same answer! good job!
