How Do You Calculate Theta for Vector Sum Using Component Method?
  • Thread starter Thread starter AraProdieur
The discussion revolves around calculating the angle theta for vector sums using the component method in a physics context. The original poster presents a problem involving two vectors, A and B, with specified magnitudes and angles, and seeks assistance with determining the angles of the resulting vectors from their sums and differences.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the component method to find angles associated with vector sums and differences. There is mention of using components to find angles, as well as references to the law of sines and cosines, raising questions about the appropriateness of these methods in this context.
Some participants have provided hints regarding the use of vector components to find angles, suggesting that the original poster may have the necessary information but is unsure how to apply it. There is an ongoing exploration of the correct approach to utilize the components for angle calculation.
The original poster has completed parts of the problem but is struggling specifically with parts that require angle calculations. There is an emphasis on adhering to the component method as per the problem statement.
AraProdieur
Use the method of components to find the magnitude and direction of the vector sum R1, where R1 = A + B. The vector A = 15.2 m at an angle alpha = 180 degrees from the positive horizontal axis, and vector B = 17.2 m at an angle Beta = 41.3 degrees from the positive horizontal axis.
Answer= 11.5784
So far I have answered the first three parts, but am stuck on looking for the angle of theta 2; I don't understand this part.
Part 2= What is the angle theta 1 from the positive horizontal axis of the vector sum, R1? 101.348 degrees
Part 3= What What is the magnitude of the vector difference R2 where R2 = A-B? 30.4247
The following are the parts that I don't understand.
Part 4= What is the angle theta 2 of the resulting vector?
Part 5= What is thet magnitude of the vector difference R3 where R 3 = B - A? Answer= 30.4247
Part 6= What is the angle theta 3 of the resulting vector?
Parts 4 and 6 are asking for the angles from the horizontal of the vectors found in the previous problems. Can you answer 5? If you were able to do 1 and 3, you should be able to do 5. If you can, you should also have the components of these vectors.
HINT: Can you use these components to find the angles?
G01 said:
Parts 4 and 6 are asking for the angles from the horizontal of the vectors found in the previous problems. Can you answer 4 and 6? If you were able to do 1 and 3, you should be able to do 4 and 6. If you can, you should also have the components of these vectors.
Yes, but in those parts, I used the law of sines and cosines, I didn't really use the components. But I do know the components although I don't know how to utilize them correctly. I'm also familiar with the usage of inverse tan, but other than that, I don't know how to do anything else with that.
The problem statement was to use the component method, not the law of cosines, right?
If you used the component method, you'd have the components for the vector you would be trying to find. Using these x and y components, you should be able to find the angle the vector makes with the horizontal. Remember that a vector makes a right triangle with its components in which it is the hypotenuse. Can you use trig to find the angle using this triangle if you knew the components?
