How do you change the magnitude of a vector?
To find the vector parallel to a + b with a magnitude of 20 units, first calculate a + b, which equals 3i + 4j. A unit vector in the direction of a + b is then determined, and its magnitude is scaled to 20. For the second part, pa + qb = c requires solving two equations based on the components of the vectors. The magnitude of a + b is essential for scaling, and recognizing common right triangle ratios can simplify calculations. Understanding these concepts is crucial for effectively changing the magnitude of a vector.
omicron
Three vectors a, b and c are such that a = i + 3j, b = 2i + j and c = i + 13j. Find
(i) the vector which is parallel to a + b and of magnitude 20 units.
(ii) the value of p and of q for which pa + qb = c
I need help in both parts.
i)
what is a+b ?
Then, what is the definition of a unit vector? And then how do you change the magnitude of a vector?
ii) What does pa mean, and qb mean? You will have two equations. One will solve the c i component, the other will solve the c j component.
what is the magnitude of a + b?
you need a vector of maginutude 20, in the same direction of a + b.
the scale of your magnitudes should be the same as the scale of your components. (check it for yourself - can you see it's just similar triangles?)
look out for this nice 3,4,5 triangle; they can simplify calculations if you spot them.
i.e where two sides are of length 3 and 4 units, while the hypotenuse is 5 units. that is, if you have a triangle with two of the sides being any two of these numbers, you know immediately the other side must be the missing number.
5,12,13 is another one to look out for. a bit trickier to spot.
These pop up frequently!
Thank you.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
