How do you solve for t in the equation d=v1(t) + .5at2?
  • Thread starter Thread starter homevolend
To solve for t in the equation d = v1(t) + 0.5at², start by substituting the known values into the equation. After simplifying, the equation becomes 4 = 0.4t², where the t term is eliminated due to being multiplied by zero. Isolate t² by dividing both sides by 0.4, resulting in t² = 10. Finally, take the square root of both sides to find t, which gives the solution in terms of seconds. This process involves basic algebra and the application of the square root to isolate the variable t.
homevolend
I use this formula for a question I am doing, I know formula is correct one to use
d=v1(t) + .5at2
I do
4=0 t + .5 x 0.8 x t2
these are correct numbers in my equation I use.
I try to finding t, but I do not know since there is a t2 at the end of the equation.
It's basic algebra. Since the t term goes away due to being multiplied by 0, you have
4 = .4 t2
You should be able to solve that with little difficulty.
Ok I have found out
t2 = 10
But is that it or do I need to just make t alone without it squared?
t2 has units of seconds2, which usually isn't very useful ;-)
You can find t very simply:
With your first equation you can use the quadratic formula to solve for t.
You could also simplify it down giving you .4t to the second equals 4 in which you divide by .4 and take the square root of 4/.4.
This may seem confusing but it is only a simple algebraic equation.your first step should be isolating your variable t (in your case). Doing this will leave you with an equation something like this: (4/0.4)=t^2. This was done by dividing over the product of 0.8 and 0.5 (0.4) and the t is canceled out of the first part of the equation because it is multiplied by zero.
Now that all of that is sorted out comes time to solve for t! after finding the quotient of (4/.4) to solve for t you must take the square root of both sides of the equation this will put t in the first power and once you take the square root of your newly found quotient you will have successfully solved for t.
