How Do You Solve the Line Integral on a Semi-circle and Line Segment?
The discussion focuses on solving the line integral \(\int_{T} (-x^2y)dx + (y^2x)dy\) over a closed curve consisting of a semi-circle and a line segment. Participants suggest using parametrization techniques, specifically converting to polar coordinates with \(x(t) = a\cos{t}\) and \(y(t) = a\sin{t}\), which simplifies the integral. The final integral can be expressed as \(2a^4\int_{t=0}^{\pi} \cos^2{t}\sin^2{t}dt\). Additionally, Green's Theorem is recommended for further understanding of non-exact integrals.
  • Understanding of line integrals and parametrization
  • Familiarity with polar coordinates
  • Knowledge of Green's Theorem
  • Basic calculus, including integration techniques
  • Study the application of Green's Theorem in line integrals
  • Learn about parametrization techniques for curves
  • Explore polar coordinate transformations in integrals
  • Practice solving integrals involving trigonometric functions
Mathematicians, physics students, and anyone interested in advanced calculus, particularly those working with line integrals and vector calculus.
mmh37
I have been working on the following line integral:
\int_{T}^- {(-x^2y)dx + (y^2x)dy}
where T is the closed curve consisting of the semi-circle x^2 + y^2 = a^2 (y>0) and the segment (-a,a)
I will tackle this in two steps:
1)
solve x^2 + y^2 = a^2 (y>0) for y and substitute into Integral
this gives \int_{-a}^a {- x^2 * root (a^2-x^2) }dx
2) integrating along the x-axis - gives zero.
My problem: How can one solve the above integral in part 1? Help is much appreciated!
Mmmh. It seems you forgot about the integral wrt to y.
What does \int_{C}y^2xdy transforms into after your paramatrization by x?
Add it in your calculations, and you'll see that you don't have any integral to evaluate.
if I substitute in I receive:
(a^2-x^2)x*dy
but dy= 0 (y^2 + x^2 = a^2 ... 2y * dy/dx + 0 = O ...dy/dx =0)
so therefore I left it out
but I have the impression that I do this wrong. thanks for your help!
This line is complete giberrish to me. What I say is, just use what you know about parametrization: if x(t), y(t) t_1 \leq t \leq t_2 is your parametrization, then the line integral \int_C P(x,y)dx + Q(x,y)dy is
\int_{t_1}^{t_2}P(x(t),y(t))\frac{dx}{dt}dt + \int_{t_1}^{t_2}Q(x(t),y(t))\frac{dy}{dt}dt
This is what you have here, except that the parametrization you chose has x for a param. variable, instead of the "outsider" t. Your parametrization is simply x(x) = x, y(x) = root{a²-x²}, -a \leq x \leq a. That's what you did so far, except you forgot about the integral wrt y. Now can you do it?
sorry about being so slow...but I still don't understand it.
this is the new integral:
\int_{-a}^{a}(-x^2) root( a^2 - x^2) dx + \int_{a}^{a}-x * root (a^2-x^2)dx = \int_{-a}^{a} ((-x^2-x)* root(a^2-x^2)dx
where \frac {dy} {dx} = \frac {-2x} {2* root (a^2-x^2)}
but how can one go on from here?
Also, since the second integral is an odd function couldn't one just ignore it, since it's value is zero anyways (I just realized that)?
Why don't you just use the plane polar coordinates? It might reduce the algebra.
Put x = r\cos t and y = r\sin t
So dx = -r\sin t dt & dy = r\cos t dt for t in the range 0 to \pi.
You have the radius r = a.
Hope this helps a little...
use instead the parameterization x(t)=a\cos{t},y(t)=a\sin{t},0\leq t\leq \pi so that dx=-a\sin{t}dt,dy=a\cos{t}dt the line integral in part (1) becomes
\int_{T} {(-x^2y)dx + (y^2x)dy} = \int_{t=0}^{\pi} (a^4\cos ^2{t}\sin ^2{t} + a^4\cos ^2{t}\sin ^2{t} )dt = 2a^4\int_{t=0}^{\pi} \cos ^2{t}\sin ^2{t}dt
you can get it from there
By the way, use \sqrt{a^-x^2} instead of root(a^2-x^2)
Wow, you have practically solved the problem :biggrin:.
which is against PF guidelines ...
Benorin, while your contribution is greatly appreciated, can you try not to give away complete solutions to the question?
Yes, but I likely should not have.
I fixed it. Sorry: my bad.
Thank you very much, siddharth. :smile: :approve:
Hey mmm37. Sorry to have lead you to believe the integrals wouls cancel. Instead, they add, which makes a mess. You should go with what Reshma and benorin suggested.
Thanks very much all of you! I don't know what I would do without your help! It is very much appreciated!
I am working on solving the integral (in polar coordinates) and I will post the answer once I got it.
Mel
On a slightly related note!
There is a theorem that applies that is quite handy, called Green's Theorem (I wholeheartedly recommend looking it up)
Basically, if dQ/dx does not equal dP/dy (meaning the integral isn't exact), then the integral is equal to the double integral over the bounded region of dQ/dx-dPdy. In this case, that leaves you with the double integral of x^2+y^2, which when converted to polar is a trivial integral. I really suggest looking up Green's (and of course, stoke's) theorem.
