How do you solve this simple differential equation?
To solve the differential equation 2 = v(t)/10 + (1/2)∫v(t)dt, the equation can be rearranged to isolate the integral. The solution involves recognizing that the resulting function resembles an exponential decay, specifically 20e^(-5t). The general solution format is A + Bexp(-kt), where A is zero in this case. The value of B can be challenging to determine without initial conditions. The discussion emphasizes the need for differentiation to eliminate the integral for a clearer solution path.
elcotufa
How would you solve
2=\frac{v(t)}{10}+\frac{\int{v(t)}}2
Thanks for your help
elcotufa said:
How would you solve
Try rearranging the equation.
\int{v_{(t)} = 4 - \frac{v_{(t)}}{5}
What function do you know that will yield this kind of result?
I know the answer is 20e^(-5t) by just taking the 1/10 out from the v(t), and the k on top of the exponential is negative 10/2 but I don't know the solving mechanismMy calc book only has one example and it is when it equals a function and not a constant in the first equation, so I can just differentiate the equation to get rid of the integral
The answer should be in the form A+Bexp(-kt)
A is zero for this equation but can I find B without any initial conditions?
Taking the common integral of e you can start with this
\int{e^{(ct)} = \frac{e^{ct}}{c}
http://en.wikipedia.org/wiki/List_of_integrals_of_exponential_functions
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
