How does a norm differ from an absolute value?
dimensionless
How does a norm differ from an absolute value? For example, is
<br /> \|\mathbf{x}\| = \sqrt{x_1^2 + \cdots + x_n^2}<br />
any different than
<br /> |\mathbf{x}| = \sqrt{x_1^2 + \cdots + x_n^2}<br />
The usual absolute value satisfies all the properties of a norm- it's just the most common example of one. You've surely met other examples of norms though.
any different than
What the norm is kind of depends on how you are defining the inner product. The example you have is for a normal dot product, but the norm for an inner product is the sqrt of the inner product...
A better definition
http://mathworld.wolfram.com/VectorNorm.html
Every inner product leads to a norm, but not all norms come from an inner product.
Strictly speaking, the term "absolute value" is used only for numbers: real or complex. The term "norm" is used for vectors. The norm is exactly the same as what you are calling absolute value but I wouldn't use that term.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
