How Does an Electric Field Cancel Out Magnetic Force on an Electron?
To cancel the magnetic force on an electron moving in a magnetic field, the electric field must be equal in magnitude but opposite in direction to the magnetic force. The relationship can be expressed as E = vB, where E is the electric field, v is the velocity of the electron, and B is the magnetic field strength. It's crucial to consider the vector forms of the equations to accurately determine the direction of both forces. The electric field direction must be opposite to the velocity of the negatively charged electron to effectively counteract the magnetic force. Understanding the relative directions of the vectors involved is essential for achieving a straight path for the electron.
jakeowens
What magnitude and direction would an electric field, E, need to be to cancel out the force on an electron traveling with speed, v, in magnetic field B?
I know the formula for the force on an electron in a magnetic field is F=qvB. The formula for the force on an electron in a electric field is F=qE. can i just set the two equal to each other? giving me qE=qvB, divide by q, giving me E=vB? is that right?
Your answer is supposed to have magnitude and direction, so you need to use the vector forms of the equations that you list. Other than that, you are on the right track. BTW, what is the shape of the path of an electron moving with velocity v in a magnetic field? When you get your E(t) field correct, the electron will go back to just a straight path with velocity v.
I don't know any information other then what was given, that's why I'm slightly confused, I am just getting messed up in the directions
The electric field has to flow in a direction (from positive to negative) in the same direction as the force from the magnetic field correct? that way the electron will be attracted back, canceling out the force from the magnetic field, allowing it to travel in a straight path. Am i right?
Actually because the electron has a negative charge, the electric field will point in the direction opposite to the direction of the velocity. I think what the question is after is the relative directions of the vectors involved, so sketch a quick diagram and make an assumption of what direction the E field is, then figure out the required direction of B.
Note: The magnetic force is NOT F=qvB. Use the vector version of this equation!
-Dan
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
