How Does Charge Distribution Affect Fields and Energy in Nested Conductors?
The discussion centers on calculating the electric field (E), electric flux density (D), and dipole moment per unit volume (P) for a system of nested conductors with specified charges. The inner solid sphere has a charge of 20 µC, while the outer spherical shell carries a charge of -10 µC, with a dielectric constant of 5 in the space between them. The electric field is zero inside the solid sphere, and calculations for the regions between and outside the conductors involve using Gauss's law. There is uncertainty about whether the inner charge contributes to the energy of the system, particularly when considering the outer shell's charge. The conversation highlights the complexities of charge distribution and its effects on electric fields and energy in nested conductors.
DR33
Here's the problem that I have been trying to solve:
A solid conducting sphere of radius 20cm is concentrically placed inside a spherical shell of inner radius 30 cm and outer radius 40cm. A Charge of 20uC is placed on the inner sphere, and a charge of -10uC is placed on the outer conductor. The dielectric constant of the medium between the 2 conductors is 5. Finc:
a) D, E and P at all points in space (all vectors)
b) the total energy in the system
Can anyone help me resolve this . Thakn you.
What do you mean by D, E and P?
E = Electric field?
D, P = ?
Thanks
D = Electric Flux Density
P = Dipole Moment per unit Volume
Anyone?
R_1 = 0.2m, R_2 = 0.3m, R_3 = 0.4m
For r < R_1,
Since the solid sphere is a conductor, the E field will be 0.
For R_1 < r < R_2,
\phi = \frac{q_{in}}{\varepsilon}
\phi = E\times 4\Pi r^2
So E = ...
For R_2 < r < R_3,
It's same with first one.
For r > R_3,
Use the method as for R_1 < r < R_2 with q_{in} being changed to -10\mu C (I don't know if the inner most charge has to be taken into account because it's bounded by the spherical conductor, correct me if I'm wrong)
As for the energy, would the inner charge contribute energy to the system?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
