How Does Lead Attenuate 0.5 MeV Photons Over 1.3 cm?
The discussion focuses on calculating the fraction of 0.5 MeV photons absorbed after passing through 1.3 cm of lead, using the linear attenuation coefficient of 0.5 cm-1. The formula I = I0e^(-ut) is applied, leading to a calculation that suggests a fraction of approximately 0.52 rather than the initially stated 3/5. Participants emphasize that lead is effective for shielding due to its high density and atomic number, which facilitate photon attenuation by interaction with lead atoms. There is confusion regarding the exponent in the calculation, with suggestions to keep I0 as an unknown intensity since the ratio of intensities will cancel out. The conversation highlights the importance of precise calculations in understanding photon attenuation.
tastytau
Calculate the fraction of photons absorbed from an attenuated beam of 0.5 MeV photons after it has gone through 1.3 cm of lead? The linear attenuation coefficient of lead for 0.5 MeV photons is 0.5 cm-1. Why is lead a good choice as a material for shielding?
I = I0e-ut
[/B]
I = 0.5 MeV e-(0.5/cmx1.3cm)
I = 0.26 = 0.3 MeV
Fraction = 3/5
Lead is effective at attenuating photons because it has a high density and high atomic number. Many photons are attenuated in lead by striking atoms.
0.5 MeV is not an intensity. And something went wrong in the exponent.
Good.
What was wrong in the exponent? I have -(0.5 cm-1 x 1.3 cm)
I don't know what else to do with the information given.
##e^{-0.5\cdot 1.3} = 0.52## not 3/5. But maybe this fraction just came from too coarse rounding.
Just keep I0 as unknown intensity. You are calculating a ratio of two intensities anyway, it will cancel in this ratio.
