How Does Touching a Violin String Affect Its Frequency?
The discussion focuses on the effect of touching a violin string on its frequency, specifically analyzing a string of length 0.33m and mass 50g under a tension of 40N. When the player touches the string at a distance of L/3, it creates a node, effectively dividing the string into two segments. The fundamental frequency is calculated using the equation f1 = 1/2L sqrt[F/μ], where μ represents the mass per unit length, leading to a new effective length of 0.22m for the vibrating portion of the string.
  • Understanding of wave mechanics and harmonic frequencies
  • Familiarity with the equation for fundamental frequency in string instruments
  • Knowledge of tension and mass per unit length in physics
  • Basic principles of nodes and antinodes in wave behavior
  • Explore the concept of harmonic frequencies in string instruments
  • Learn about the impact of tension on string vibration frequencies
  • Research the calculation of mass per unit length (μ) for different materials
  • Investigate the effects of altering string length on pitch and frequency
Musicians, physics students, and string instrument makers interested in understanding the principles of sound production and frequency modulation in stringed instruments.
clipperdude21
[SOLVED] Violin String and Waves
1. A violin string of length 0.33m and mass 50g is under a tension of 40N. A violin player touches the string a distance L/3 from one end, which produces a node at that point. What is the lowest frequency that can now be produced on the string?
2. I have several equations but they involve the funamental frequency
3. I tried solving this problem using the equation f1= 1/2L sqrt[F/mew] where mew is the mass per unit length. For the L i used 0.33- 0.33/3 to get 0.22m. This is the part I am not sure about. Is this the new length or is something else up. Thanks!b]
There are effectively two strings now, with the same T/mew ratio. The lowest note would be the fundamental harmonic of the longer portion.
great, so i did it right. Thanks!
  • · Replies 26 ·
13K
10K
