How Far Does the Ball Travel After the String Is Cut?
A 140g ball on a 60 cm string is swung in a vertical circle, with a tension of 6.9 N at the bottom. When the string is cut, the ball's initial velocity is calculated to be approximately 5.44 m/s. The height from which the ball falls is 1.4 m, leading to a time of flight of about 0.53 seconds. The horizontal distance traveled by the ball before hitting the ground is calculated to be approximately 2.9 m. The discussion emphasizes the importance of considering both tension and gravitational forces in the calculations.
Lamnia
A 140g ball on a 60 cm long string is swung in a vertical circle about a point 200 cm above the floor. The tension in the string when the ball is at the very bottom of the circle is 6.9 N. At the very bottom of the circle, a very sharp knife is suddenly inserted to cut the string directly below the point of support.
How far to the right of where the string was cut does the ball hit the floor?
Express your answer using two significant figures.
F_r net = T = (m*v^2)/r
F_z net = 0 = n - m*g (I'm under the impression that this equation isn't necessary to solve the problem as we are (rather, I am) not needing to find a friction force.)
s_1 = s_0 + v_0t + 1/2at^2
T = 6.9N
m = 0.140kg
r = 0.60m
6.9N = (0.140kg*v^2)/0.60m
v = 5.43769 m/s
y_1 = 0
y_0 = 2m - 0.6m = 1.4m
v_0 = 0
a = g = 9.80m/s^2
1.4m = .5*9.80m/s^2*t^2
t = 0.534522s
x_0 = 0
v_0 = 5.43769 m/s
a = 0
t = 0.534522s
x_1 = 5.43769 m/s * 0.534522s
x_1 = 2.9m
Above is my 5th attempt at this problem. It, too, is incorrect. I thought that determining the velocity through the sum of radial forces, and then using projectile motion kinematics would finally prove the correct approach. I have one more attempt to receive any credit for my work. Any input would be most appreciated.
At the bottom of the loop, you don't think that gravity might not also add to the tension on the string?
So... when I took F_r net = T = m*g + (m*v^2)/r, my calcs proved spot on. Thanks, again, LowlyPion :)
Cheers.
