How far will a car travel in 15 min at 20 m/s?
  • Thread starter Thread starter maro_toni
    Car Travel
To determine how far a car travels in 15 minutes at a speed of 20 m/s, first convert the time from minutes to seconds, resulting in 900 seconds. The distance formula is used, where distance equals speed multiplied by time. By calculating 20 m/s multiplied by 900 seconds, the result is 18,000 meters, which converts to 18 kilometers. The discussion confirms the calculations and conversions are correct.
maro_toni
QUESTION: How far will a car travel in 15 min at 20 m/s?The answer was 18 km. but i don't know from where did they get this answer...can you explain it please step by step??
Thank you =)
Hint: Look at the units.
The car's speed is given in meters/second
The time is given in minutes
The answer is given in kilometers
So,we'll convert 15 min. to sec. = 900 s
meters into kilometers = 0.02 m
distance = 0.02 X 900 = 18 km.
Right??
You got it!
zgozvrm said:
You got it!
Thank You Brother thank you =))
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
